export texture scale
hi
when i export a materia's texture using IExport  ,i found a problem:
set two material's texture:  scale's   sample size  : 1193.8mm,1175.15mm;
 when i export data ,i got different number for "texture_RealWorldScale":
1: masonry:
<texture_RealWorldScaleX>3.91666666666667</texture_RealWorldScaleX>
<texture_RealWorldScaleY>3.85546875</texture_RealWorldScaleY>
<texture_UScale>1</texture_UScale>
<texture_UVScale>1</texture_UVScale>
<texture_VScale>1</texture_VScale>
2:wood:
<texture_RealWorldScaleX>47</texture_RealWorldScaleX>
<texture_RealWorldScaleY>46.26</texture_RealWorldScaleY>
when i import the model in unity ,i setting the texture's tiling use RealWorldScale ,but wrong.
i think the different materia have different calculate scale?
How to calculate the different?what is the standard?
sorry for pool english!
thanks very much!
Revitalizer
this may be interesting for you:
https://forums.autodesk.com/t5/revit-api-forum/exporting-revit-2017-model-materials-using-a-customex...
If you export a DXF file, there can be found additional texture information which can be extracted.
As for the scaling topic, for my Material 248403, I can find:
<Material id="RevitMaterialDefinition248403" app="REVIT" Background="0" Backlight="1" Sample="0" Tiling="0">^J<LinearUnits unitType="foot" unitScale="1.0"/>^J<ArchitecturalMaterial name="MyTexture">^J<ArchTemplateParameters name="MyTexture" classid_A="2008828122
300
" classid_B="14503598">^J</ArchTemplateParameters>^J<ArchMatParameters>^J<ArchDiffuseColor>^J<RGBf r="0.0000" g="0.0000" b="0.0000"/>^J</ArchDiffuseColor>^J<ArchIndexOfRefraction>1.0000</ArchIndexOfRefraction>^J<ArchTransparency>0.3000</ArchTransparency>^J<ArchLu
300
minance>0.0000</ArchLuminance>^J</ArchMatParameters>^J<MapSet>^J<MapLib>^J<TextureMap name="MyTexture texture" id="RevitTextureDefinition248403">^J<BitmapMap>^J<TexMapCoords2d>^J<TextureCoords>^J<ExplicitMapChannel CoordPlane="uv">^J<MapChannel>1</MapChannel>^J<UCoor
300
ds>^J<OffsetCoord>0.0000</OffsetCoord>^J<TilingCoord>0.0000</TilingCoord>^J<TextureTiling Tiling="tile"/>^J</UCoords>^J<VCoords>^J<OffsetCoord>0.0000</OffsetCoord>^J<TilingCoord>0.0000</TilingCoord>^J<TextureTiling Tiling="tile"/>^J</VCoords>^J</ExplicitMapChannel>
300
^J</TextureCoords>^J</TexMapCoords2d>^J<BitmapParameters>^J<BitmapFile filename="D:\MyTexture.jpg"/>^J<Cropping on="0" CropType="crop">^J<UCrop>0.0</UCrop>^J<VCrop>0.0</VCrop>^J<WCrop>1.0</WCrop>^J<HCrop>1.0</HCrop>^J</Cropping>^J</BitmapParameters>^J</BitmapMap>^J</>
Maybe you can find your values this way, it's just an idea.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
thank you very much for your review!
i export data to dxf,but  no change for modify "sample size " in revit .
i try export to XML :
if i change sample size in revit  ,only "texture_realWorldScale" changed,so i think it right,but how it works?
thank you for your reply!
Revitalizer
you could browse the Assets:
http://thebuildingcoder.typepad.com/blog/2016/10/list-material-asset-texture-and-forge-webinar-recor...
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
do you know how can I get the scale's sample size of material from the Revit SDK?
thanks.
After my enquiry is due to the unit inconsistent, may be the difference between feet and inches brackets.
