Run ExternalEvent when some element is selected.
qoreodlf37
qoreodlf37
Hi.
I know that I should use ExternalEvent to do somthing with Transaction in window that opened by Show() not ShowDialog().
This is my sample code.
////This code is run in window by Show()
////externalEventHandeler is custom handler with ExternalEvent and IExternalEventHandler
externalEventHandeler.Event += (s, arg) => {
          //Do something with Transaction.
externalEventHandeler.Run();
It usually works well. But when element is selected, the event doesn't run. But the event run when I unselect element.
I searched and understand the reason is Revit UI thread holding 'Element select'.
I want to know run event withoue unselecting element.
How can I do?
scgq425
Hi @qoreodlf37 :
this error likely push by the thread changed and the external cant notify .
you can try this step :
1. run code
2. click revit main window and check that :select element
3. also you can use this code to set window be revit child
wpf :
 LoginWindow window = new LoginWindow();
            System.Windows.Interop.WindowInteropHelper mainUi = new System.Windows.Interop.WindowInteropHelper(window)
                    Owner = System.Diagnostics.Process.GetCurrentProcess().MainWindowHandle
            window.ShowDialog();
winform:
var uiView = uiDoc.GetOpenUIViews().First(x => x.ViewId == uiDoc.ActiveView.Id);
            var rec = uiView.GetWindowRectangle();
            var handler = new FindForm.ExecuteEventHandler();
            var externalEvent = ExternalEvent.Create(handler);
            var rvtPtr = Process.GetCurrentProcess().MainWindowHandle;
            FindForm ff = new FindForm(handler,externalEvent,new Point(rec.Left,rec.Top));
            ff.Show(new Command.WindowHandle(rvtPtr));
 public class WindowHandle : IWin32Window
            private IntPtr _handle;
            public WindowHandle(IntPtr h)
                Debug.Assert(IntPtr.Zero != h, "expected non-null window handle");
                LogUtility.Error("expected non-null window handle");
                _handle = h;
            public IntPtr Handle => _handle;
4. if this all null , using the idling + external to select element ,  make the thread to revit
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
ricaun
What do you mean by element is selected?
Are you selection a element and than click in a button to run the externalEventHandeler?
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
