Rubber Band DirectContext3D API
jose_marquez5Z5GC
jose_marquez5Z5GC
Hi everyone,
I have a question does someone knows how to Refresh the Active View with Revit rendering loop Tick Event.
This is my issue I created a rubber band command that draws a line between the first point and the cursor position on the screen, the way I'm refreshing the view is subscribing to the Idling Event and force Refresh the view, in that way the SceneRender method get called and the line is redraw again, giving the effect of a rubber band. My issue is that I want to use the snap functionality of the PickPoint() method but when PickPoint is active the Idling event doesn't fire as expected, that's why I need another way to refresh the view or a different approach does anybody knows of a solution.
Thanks before hand.
rcrdzmmrmnn
Can't you just use model line command? I have a similar workflow.
I activate an Iupdater, then, post command of model line. In the Updater I gather necessary info about the model line created, do stuff, and then ,delete the model line and deactivate the updater
ricaun
You need to refresh the view using other event, usually in the event that tracks the mouse movement/position.
This is a sample does that with a rectangle using PickPoint and DirectContext3D.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
jose_marquez5Z5GC
Awesome solution I implemented and I'm using it in every adding that needs that type of interaction, thanks
jose_marquez5Z5GC
I implemented the rubber band but have limitations for the second point, I cannot use the snaps from Revit making a lot more difficult the implementation, thanks anyways, this push me to learn the context 3D API
