Revit tolerance error
Hello, I am trying to use a package in Dynamo. However, anytime I try, I get error named "Curve length is too small for Revit’s tolerance ….Parameter name Endpoints”. Could you tell me the reason, why I get this error all the time.
AGGilliam
How small is the curve? I don't recall the size but Revit does have a minimum line size and it seems like that could be what's happening. I don't use Dynamo, but ran into a similar error trying to create sheet metal families.
aignatovich
See Application.ShortCurveTolerance property value. This is the minimum curve length value. For spline curves this is also the minimum distances between its start and end
Yien_Chao
I believe the shortest length for a curve in Revit is around 0.7-0.8mm
