REVIT TO ETABS
REVIT TO ETABS
1001954608UMYK2
REVIT TO ETABS
1001954608UMYK2
Hi, i am trying to import my structural model in revit to etabs. I am currently using the ifc format to do so, and I need to know if there are any limitations as a result of doing so, or if the imported model would be just as editable as if we were to model it directly on etabs.
If such is the case, is there any alternatives for me to load my model revit to ETABS without any limitations? I would hate having to do my model all over again.
attached is my revit model, and shown below is the resulting etabs file
jeremy_tammik
Are you doing anything programmatically yourself making use of the Revit API? If not, your question will probably receive more competent attention and answers in the Revit Structural forum. Please note that this discussion forum is dedicated to programming Revit using the Revit API:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
