How to position a FamilyInstance with the elements of Transform?
pmeigneux
pmeigneux
I want to position Family instances using BasicX, BasicY, BasicZ as well as Origin information.
I didn't prove in Create.NewFamilyInnstance this possibility so I used Doc.Create.NewFamilyInstance(xyz, familySymbol, Autodesk.Revit.DB.Structure.StructuralType.NonStructural);
How to do the rotations so that the positioning is correct?
jeremy_tammik
I am not aware of any method named NewFamilyInnstance with two lower-case 'n'. NewFamilyInstance comes equipped with quite a number of different overloads:
You need to choose the appropriate overload depending on the type of instance and instance placement that your specific family requires. Arbitrary free-floating placements in space are quite unusual within a building. Most BIM elements need some kind of support that is provided by some other BIM host element.
Here are some further discussion of various placement options:
architect.bim
Hi!
To rotate the created FamilyInstance get its Location and use the Rotate method:
f_instance = doc.Create.NewFamilyInstance(origin, f_symbol, structural_type)
f_instance.Location.Rotate(
    DB.Line.CreateUnbound(origin, DB.XYZ.BasisZ),
    angle
To calculate the angle use math trigonometric functions or AngleTo method.
Maxim Stepannikov | Architect, BIM Manager, Instructor
pmeigneux
// Prepare rotate
Transform PositionAbs = ...;
XYZ axisX = PositionAbs.OfVector(PositionAbs.BasisX);
XYZ axisY = PositionAbs.OfVector(PositionAbs.BasisY);
XYZ axisZ = PositionAbs.OfVector(PositionAbs.BasisZ);
// rotate by X axis
double rotXRadian = PositionAbs.BasisX.AngleTo(axisY);
// rotate by Y axis
double rotYRadian = PositionAbs.BasisY.AngleTo(axisZ);
// rotate by Z axis
double rotZRadian = PositionAbs.BasisZ.AngleTo(axisX);
No Rotate ==> rotXRadian = rotYRadian  = rotZRadian  = Pi/2
Rotate 180 degre on X ==> rotXRadian  = Pi/2
It does not work..
Philippe.
