revit failed to istall
when i try to install the revit 2018 i got this message
1: 5 2;ERROR:adminPITSetCustomipmflagValue() API failed 3:12
how can i solve it ?!
jeremytammik
You already asked this question, and I already answered it here:
https://forums.autodesk.com/t5/revit-api-forum/proplem/m-p/8058136
Sorry, but this is the wrong forum for your question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
