ExternalResourceReferences change information and reload it
dor_r
dor_r
I have a RevitLinkType object
and I get GetReferenceInformation() from this object.
I want to change the information, and reload it.
It is possible?
jeremytammik
Dear Dor,
Thank you for your query.
Looking at the methods, it does not look possible to me.
All I see is the possibility to create a new ExternalResourceReference representing a local file managed by Revit's built-in server using the CreateLocalResource method:
http://www.revitapidocs.com/2018/457745f0-5346-77ed-444b-554295ebb14b.htm
Do you see the possibility to modify that information anywhere in the user interface?
In general, if Revit does not provide functionality via the UI, the API will not do so either.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
