revit ExtensibleStorage reading and writing permission setting occur exception
I am using Revit ExtensibleStorage.when I set the ExtensibleStorage reading and writing permission, occur exception:"The vendorId is invalid. Parameter name: vendorId".I use "com.hongwa" as my vendorId and I am sure that the vendorId in the addin file and in the code is same.It work well in the revit 2017,but it occur exception:"The vendorId is invalid. Parameter name: vendorId" in the revit 2016. The flowing is my code for the ExtensibleStorage reading and writing permission  setting :
buider.SetApplicationGUID(new Guid("f35e4672-0a3e-4514-b105-6a636aa9f344"));
buider.SetReadAccessLevel(AccessLevel.Vendor);
buider.SetWriteAccessLevel(AccessLevel.Vendor);
buider.SetVendorId("com.hongwa");
I found the SetVendorId api remark:"The vendor id is the registered developer symbol. The registration interface is available at http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1075006 Since vendor ids are not case sensitive, the string will be converted to upper case before it is stored in the schema." when I go to the url,it show:"Symbols registration has been retired and is no longer available. If you have any questions please contact Dev-Req@autodesk.com  "
have someone can help me?
thanks.
CADsoftOrl
I've just run into this same issue.  2017 takes my VendorID but 2016 throws an exception.  Anyone have an answer for this issue?
matthew_taylor
Hi @CADsoftOrl,
The VendorId field changed in Revit 2017. In 2016 and prior, it was a registered developer symbol, which was 4 characters long.
In 2017 this changed to a sort of reverse website naming convention (of your company).
Id your VendorId over 4 characters long? Check out the VendorIdIsValid method. Does your VendorId pass this for both versions? You'll want it to pass both so you can deal with upgraded Revit models.
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
