how to get the reference of a PlanarFace
hello,I'm a beginer of Revit API and I'm learning how to use API to make families.
I want to use  the method NewAlignment, which need the reference of two planes. I've got one of the reference of a ReferencePlane via the method "referencePlane.GetReference()", while I can't get the reference of a  PlanarFace via "planarFace.Reference", it seems that there is no reference of the planarFace at all.(because a System.NullReferenceException occured ).
here are my  codes:
 void addAligments(Extrusion pBox,Document doc)
        View pView = findElement(typeof(View), "Front",doc) as View;
        Level upperLevel1 = findElement(typeof(Level), "Upper Ref Level",doc) as Level;
        Reference ref1 = upperLevel1.GetPlaneReference(); ;
        PlanarFace upperFace = findFace(pBox,new XYZ(0.0,0.0,1.0),null);
        Reference ref2 = upperFace.Reference;
        doc.FamilyCreate.NewAlignment(pView, ref1, ref2);
        Level lowlLevel1 = findElement(typeof(Level), "Lower Ref. Level", doc) as Level;
        Reference ref3 = lowlLevel1.GetPlaneReference();
        PlanarFace lowerFace = findFace(pBox, new XYZ(0.0, 0.0, -1.0),null);
        Reference ref4 = lowerFace.Reference;
        doc.FamilyCreate.NewAlignment(pView, ref3, ref4);
        View pViewPlan = findElement(typeof(ViewPlan), "Lower Ref. Level",doc) as View;
        ReferencePlane refRight = findElement(typeof(ReferencePlane), "Right",doc) as ReferencePlane;
        ReferencePlane refLeft = findElement(typeof(ReferencePlane), "Left",doc) as ReferencePlane;
        ReferencePlane refFront = findElement(typeof(ReferencePlane), "Front",doc) as ReferencePlane;
        ReferencePlane refBack = findElement(typeof(ReferencePlane), "Back",doc) as ReferencePlane;
        ReferencePlane refOffsetV = findElement(typeof(ReferencePlane), "OffsetV",doc) as ReferencePlane;
        ReferencePlane refOffsetH = findElement(typeof(ReferencePlane), "OffsetH",doc) as ReferencePlane;
        PlanarFace faceRight = findFace(pBox, new XYZ(1.0, 0.0, 0.0), refRight);
        PlanarFace faceLeft = findFace(pBox, new XYZ(-1.0, 0.0, 0.0),null);
        PlanarFace faceFront = findFace(pBox, new XYZ(0.0, -1.0, 0.0),null);
        PlanarFace faceBack = findFace(pBox, new XYZ(0.0, 1.0, 0.0), refBack);
        PlanarFace faceOffsetV = findFace(pBox, new XYZ(1.0, 0.0, 0.0), refOffsetV);
        PlanarFace faceOffsetH = findFace(pBox, new XYZ(0.0, 1.0, 0.0), refOffsetH);
        doc.FamilyCreate.NewAlignment(pViewPlan, refRight.GetReference(),faceRight.Reference);
        doc.FamilyCreate.NewAlignment(pViewPlan, refLeft.GetReference(),faceLeft.Reference);
        doc.FamilyCreate.NewAlignment(pViewPlan, refFront.GetReference(),faceFront.Reference);
        doc.FamilyCreate.NewAlignment(pViewPlan, refBack.GetReference(),faceBack.Reference);
        doc.FamilyCreate.NewAlignment(pViewPlan, refOffsetV.GetReference(),faceOffsetV.Reference);
        doc.FamilyCreate.NewAlignment(pViewPlan, refOffsetH.GetReference(),faceOffsetH.Reference);
Thank you for your help.
Are you setting  ComputeReferences  = true in the GeometryOptions object you are using to extract the faces?
Also, when passing face references to dimensions  and alignments you need to use the references extracted from symbol geometry not instance geometry.
thank you, I make it.
