Keynote Files
Keynote Files
Keynote Files
I am currently using Revit 2015. I am working on a routine that copies my company's standard keynote file to my central model's location and renaming based on the project number parameter. Is it possible to take it a step farther and apply that keynote file to the model?
PhillipM
Sure you can.  Code below.
Dim p As ModelPath = ModelPathUtils.ConvertUserVisiblePathToModelPath(My.Computer.FileSystem.SpecialDirectories.Temp + "\tmpknFile.txt")
            Dim s As ExternalResourceReference = ExternalResourceReference.CreateLocalResource(commandData.Application.ActiveUIDocument.Document, ExternalResourceTypes.BuiltInExternalResourceTypes.KeynoteTable, p, PathType.Absolute)
            t = New Transaction(commandData.Application.ActiveUIDocument.Document, "Reload")
            t.Start()
            knTable.LoadFrom(s, Nothing)
            t.Commit()
Thank you! I believe in the past this was considered not possible.
ModelPath p = ModelPathUtils.ConvertUserVisiblePathToModelPath("whatever:\\whatever\\KeyNotes"+ "\\TheUserKeyNotesFile.txt");
			ExternalResourceReference  s = ExternalResourceReference.CreateLocalResource(doc, ExternalResourceTypes.BuiltInExternalResourceTypes.KeynoteTable, p, PathType.Absolute);
     			try {
			        		using (Transaction t = new Transaction(doc, "UserKeynoteFileReload")){
							t.Start();
							KeynoteTable.GetKeynoteTable(doc).LoadFrom(s,null);
							t.Commit();
			        	} catch (Exception) {
			        		throw;
PhillipM
Only available in 2015 & Above
Is there any reason that I couldn't use this code to reload the keynote file?
PhillipM
Reloading is even easier.
 Dim knTable As KeynoteTable = Autodesk.Revit.DB.KeynoteTable.GetKeynoteTable(doc)
        Dim lr As New KeyBasedTreeEntriesLoadResults
        Dim t As New Transaction(doc, "Reload")
        t.Start()
        knTable.Reload(lr)
        t.Commit()
Reason could not, I don't know. I changed to use the Reload method instead of the LoadFrom but I am still verifying the file exists before Reloading so that the message to the user can be more informative.
