Revit Cloud Rendering and Redirect Issue
Hello Dear,
I need to subscribe to  Revit cloud on autodesk, and I need clarifications for the following inquiries please:
1-    Is Revit cloud supports multiple users “engineers” for the same project with different access levels,
i.e. I need to create admin role with full permissions , admin can add edit all projects, and every working engineer can only edit his/her own work,
and see others engineers work but couldn’t edit it, also I need the client to review and monitor  the work but without editing, or downloading the project.
2-    Is there limited number of engineers can work in the same project? If yes what is the max number of engineers can work in the same project.
3-    I need to know the price to subscribe from inside Egypt, the size or quota that will be available,  and number of projects for the subscription.
4-    If the features stated in #1 not included in the cloud website? Is there APIs that I can use to create my own website? How can I get them?
Your quick reply is very appreciated.
jeremytammik
Dear Eman,
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Your question is a mix of a small portion of API questions and a large piece of end user product interaction.
I general, the Revit API does not provide much support for any functionality that is not available through the end user interface.
Therefore, I suggest that you clarify your issue from the end user point of view first.
You could try one of the non-API Revit product support discussion forums for that:
http://forums.autodesk.com/t5/revit-api/this-forum-is-for-revit-api-programming-questions-not-for/td...
The people there are much better equipped to answer your question than us programming nerds.
Once that is clear, we can better address the API side of things.
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hello Jeremy,
thank you for your reply, Ok i got your point.
but I want to ask you about the API features, do you have any document for it? where can i find it?
Ema
Hello Jeremy,
Ema
jeremytammik
Dear Ema,
Greta!
Yes, absolutely.
Here is an overview of the Revit API getting started material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Good luck and much success exploring and architecturing a perfect solution for your needs!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
