Revit application interface bugging out...
Using 2018.3 on a GEFORCE GTX 1060. Have been running Revit on this computer for a total of about 50 hours so far...have had no issues prior. It suddenly began to "bug out" and when I move across the ribbon the following happens (see screenshots. It's also interfering with button selection at affected areas, so workflow is gone. You have to click "through" the bug to active the button, sometimes several times. Anyone have any experience with this issue?
jeremytammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
My apologies. I associated "programming" with "interface". Thank you for
your understanding.
