getting original geometry volume for structural framing from API
natanatalili
Message 1 of 1
natanatalili
Hi all
I would like to get the original volume for concrete structure framing which are joined to structural slab from API.
I tried snoop a selected Structural framing element in a 3D view using Revit Lookup and i can successfully get the original geometry volume.
However, when the structural framing are connected between column/wall, I found that the original geometry volume is not correct.
Below images are the capture for the section views of those cases, showing the volume that I get from Revit Lookup and the expected volume which I calculated by hand.
I wonder why the original volume taken from Revit API is different from my calculation by hand?
Replies (0)
