Revit API - Print Order
Pei_LiuQ5B9P
Pei_LiuQ5B9P
Does anyone know which API I should use to control print order settings? I manually set the print order by sheet number via the UI. However, when I add a sheet to the print set programmatically using ViewSheetSet.Views, it automatically changes the setting to "Manual." Which property should I change to ensure the print order is always set by Sheet Number?
Thank you.
moturi.magati.george
Hi @Pei_LiuQ5B9P,
There are a few samples done in the Revit SDK on the same. Kindly have a look
https://github.com/jeremytammik/RevitSdkSamples/tree/master/SDK/Samples/ViewPrinter/CS
You can download the full Revit .NET SDK at https://aps.autodesk.com/developer/overview/revit
  Moturi George,     Developer Advocacy and Support,  ADN Open
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Pei_LiuQ5B9P ,
Please take a look at the IViewSheetSet interface.
This will help you modify the print order by accessing or arranging the list.
Please refer to the links below.
https://thebuildingcoder.typepad.com/blog/2022/04/whats-new-in-the-revit-2023-api.html#4.2.22
https://www.revitapidocs.com/2020.1/4c3ef0b6-6d63-1e58-cff4-aabd4d8f75a2.htm
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Pei_LiuQ5B9P
Thanks all. I had actually used the way you mentioned; however, for some reason, it didnt' work. After I reboot my PC, it worked.....
Thanks!
