Opening a document wihtout loading links
Khadourwaseem
Khadourwaseem
Anyone has any idea how I can open revit docs without loading links, I saw there is an app for that in the appstore you didn't find anything in the API docs.
-Closing all worksets doesnt really work, since I batch open hundred of files, and not all of them have worksets correctly created
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Khadourwaseem ,
When WriteTransmissionData is called with a TransmissionData object that has all references set to LinkedFileStatus.Unloaded, no references will be loaded the next time the document is opened.
Please take a look at this below link
https://help.autodesk.com/view/RVT/2024/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Advanced_Topi...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
