Export view in image : how to change the line weight ?
frederic.suard
Observer Observer
Message 1 of 1
frederic.suard
Observer
Observer
We are using the ExportImage function of the API in order to save locally the generated image.
We have an issue with some DWG when the lines of some layers are associated with a large weight.
This option can be changed manually throught the Manage menu and ObjectStyle planel, but we would avoid such manipulation.
The result we would obtain is when the active view has the option of Thin Lines display.
Similar topics does not provide solution like https://forums.autodesk.com/t5/revit-api-forum/c-revit-2019-the-default-value-of-the-quot-doc-export...
So is it possible to change all weights of lines (even with CAD import) or to obtain the "Thin Lines" option during image export ?
Thanks 🙂
Replies (0)
