Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit API in VSTO Project
1 REPLY 1
sasuarezr
133 Views, 1 Reply
Hi everyone,
I would like to know if it is possible to use the Revit API inside an Excel VSTO project, and if so then how should I set up the project in Visual Studio. What I want is to be able to interact with a Revit file from an Excel Add-In through a custom Excel ribbon tab made in a VS Excel VSTO Add-In project.
Thanks in advance,
Sincerely, Santiago
Labels (2)
1 REPLY 1
jeremy_tammik
in reply to: sasuarezr
No, not directly:
The Revit API requires a valid Revit API context. Such a context is only provided within the event handler of a Revit API event. Such an event requires a running Revit add-in and a running Revit session.
Yes, indirectly:
You can presumably achieve what you need anyway, by implementing a Revit add-in that defines an external event:
https://www.revitapidocs.com/2024/05089477-4612-35b2-81a2-89c4f44370ea.htm
You can raise the external event from your Excel add-in and access the Revit API in the event handler.
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
Forma Design Contest
Rail Community
