Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit Add-in Runs First Time Only
6 REPLIES 6
SillyLucky2_0
446 Views, 6 Replies
I have created an add-in to create documents/drawings. The creation of the documents has been tested and works. I have a Form with a few checkboxes to allow the selection of what file types are needed. The issue I am having is the first time I open Revit and run the add-in, everything functions correctly. However, when I try to use the add-in a second time in the session, the form opens, but on submit_click, nothing happens. The dialog closes and nothing happens. Any insight as to why it works the first time and not after that would be appreciated. Class and Form scripts can be found below. Sorry for the length of the scripts, I tried to remove all unnecessary items.
Class.cs
namespace ProjectPrintingOptions
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Autodesk.Revit.ApplicationServices.Application app = uiapp.Application;
            Document doc = uidoc.Document;
            ProjectPrintForm Form1 = new ProjectPrintForm(commandData);
            Form1.ShowDialog();
            //Create ViewSet of sheets for printing/exporting
            ViewSet mySheets = new ViewSet();
            using (Transaction trans = new Transaction(doc))
                try
                    trans.Start("Print PDFs");
                    //Code to set print settings and export settings
                    foreach (ViewSheet vv in mySheets)
  			//Code to print and export sheets as needed
                    trans.Commit();
                catch (Exception e)
                    Debug.Print(e.Message);
                    trans.RollBack();
            return Result.Succeeded;
Form.cs
    public partial class ProjectPrintForm : System.Windows.Forms.Form
        private UIApplication uiapp;
        private UIDocument uidoc;
        private Autodesk.Revit.ApplicationServices.Application app;
        private Document doc;
        public ProjectPrintForm (ExternalCommandData commandData)
            InitializeComponent();
        private void Box1checkbox_CheckedChanged(object sender, EventArgs e)
        private void Box2checkbox_CheckedChanged(object sender, EventArgs e)
        private void Box3checkbox_CheckedChanged(object sender, EventArgs e)
        private void Box4checkbox_CheckedChanged(object sender, EventArgs e)
        public bool Box1Test
            get { return Box1checkbox.Checked; }
            set { Box1checkbox.Checked = value; }
        public bool Box2Test
            get { return Box2checkbox.Checked; }
            set { Box2checkbox.Checked = value; }
        public bool Box3Test
            get { return Box3checkbox.Checked; }
            set { Box3checkbox.Checked = value; }
        public bool Box4Test
            get { return Box4checkbox.Checked; }
            set { Box4checkbox.Checked = value; }
        private void cancelButton_Click(object sender, EventArgs e)
            cancelButton.DialogResult = DialogResult.Cancel;
        private void submitButton_Click(object sender, EventArgs e)
            submitButton.DialogResult = DialogResult.OK;
            Close();
            return;
6 REPLIES 6
scgq425
in reply to: SillyLucky2_0
Hi @SillyLucky2_0 : i uncomplete to saw the targer problem , but whih the description , this problem like the form-parameter not display , u can debug the code , can check some check statement or push more code to thia page.
Thanks to @scgq425  for the helpful suggestion. I agree; there are various options that you can set on the Windows form component that affect how the buttons behave, e.g., when closing the form; maybe some of those settings are involved in this behaviour.
nia98bim
    try
        ProjectPrintForm form = new ProjectPrintForm(commandData);
        form.ShowDialog();
        if (form.DialogResult == DialogResult.OK)
            using (Transaction trans = new Transaction(doc, "Print PDFs"))
                trans.Start();
                // Code to set print settings and export settings
                ViewSet mySheets = form.SelectedSheets; // Assuming ProjectPrintForm exposes SelectedSheets
                foreach (ViewSheet sheet in mySheets)
                    // Code to print and export sheets as needed
                    // Ensure you have proper logic here to handle each selected sheet
                trans.Commit();
    catch (Exception e)
        message = e.Message;
        return Result.Failed;
GaryOrrMBI
@SillyLucky2_0 ,
Quick question: Is the failure on second run of the function something that you ran into while testing the function and you're trying to resolve it before putting it into the production environment?
If it is then, are you selecting the same views to print both times? Are you using the same output file names and/or location? If so, you are perhaps running into an error when trying to overwrite existing files. Your Try/Catch block may be causing the silent exit in Revit. If you're loading and running the command from within Revit as opposed to running it in debug mode you will not be seeing the Debug.Print(e.message) call from the failure of the Try/Catch block.
You can test this by either running it in debug mode from your authoring program or by changing (or adding a line to) the Catch to call up a Revit TaskDialog to show you the error within the Revit environment.
All of this assumes that you got carried away deleting stuff to create your post-able version of the command (since I don't see you checking for the returned value from the form).
Good luck
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
the same opinion as nia98bim. It seems you not returning anything to main command in the form.
change these to
this.DialogResult = DialogResult.Cancel;
this.DialogResult = DialogResult.OK;
 so that your code in command area can read it.
And if the Boxcheckboxs will get or change something immediately. Check it would get or set correct value or not when the second time you open form.
Thank you to everyone for the helpful suggestions. The windows form turned out to not be the issue and it was within my print settings. The issue was committing the transaction with all of the print settings. It was failing to save the print settings over the top of the print settings that were saved previously. I'm confused why it was working for me when I was adding the settings without the form. I have adjusted it to rollback the print settings and now it's working properly. Sorry for asking the wrong question, I appreciate everyone taking time to look into it.
Rail Community
