How enable calculate totals for columns in schedules
ptcymas7
ptcymas7
With what methods, approach, I can get that behaviour in Revit 2022? Currently I can get the next schedule using the api:
I wanted have the totals of the area, for example, [603m2, 19m2, 622m2]. In the same way that the counts.
In Revit it's enabling the format option "calculate totals" in the desired parameter, but how with the api?
I only found the method:
But this method only checks if the parameters can show the totals that I wanted, not enable the calculation
Thanks 🙂
Speed_CAD
Hi ptcymas7,
If you mean what is shown in the attached image (red box), then you must use the DisplayType option of the ScheduleField. For example:
ScheduleField scheduleField = viewSchedule.Definition.GetField(0);
scheduleField.DisplayType = ScheduleFieldDisplayType.Totals;
Mauricio Jorquera
ptcymas7
Man, that's just what I wanted. Thanks, I love u ❤️
