Message 1 of 26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Does anyone know when Revit 2025 will be released?
The exact date
Thanks 🙂
The exact date
Thanks 🙂
My bet was on March 30, 2024. Didn't happen, probably this week going to be released.
Available to me in my account 🙂
Yes, it is available in my account as well, I suppose Autodesk messed up with the download link.
Ahahahaha
P.S: Triple walls are of course very important and necessary (No)
but how about adding a calculation of the cable trajectory, taking into account... the architecture of the building?
After 18 years of development?
after watching it the only thing that they did is triple walls.
I doubt that they fix problems and bugs in gbxml
ifc is probably poor as it was
the carbon analysis is basically multiply two data and if I now Revit developers that mean that every thing we have to provide.
I can't wait what kind of mess they did in API and how much bugs they didn't fix
I did some tests in the API:
The most interesting is the RegisterContextMenu which is new in this version.
Update to .NET Core gonna be a pain in some old projects.
@ricaun .Net 8 will be a problem for those who initially did not use the SDK style (and such are the majority), in general developers can easily support all versions of .NET and Revit API in one solution. I guess move to the new version will be a great practice and developmental boost for a lot of people
@nice3point wrote:@ricaun .Net 8 will be a problem for those who initially did not use the SDK style (and such are the majority), in general developers can easily support all versions of .NET and Revit API in one solution. I guess move to the new version will be a great practice and developmental boost for a lot of people
By default, nobody uses SDK style. I only started using it because you shared something a long time ago, and I was searching and developing a way to automate my workflow, the SDK style made the csproj easier to work and nuke fit like a glove.
@ankofl wrote:Please @ricaun , do you have the opportunity to check if the transaction commit rate (.Commit()) has increased when switching the Revit API to Net.8 ?
What do you mean? If Commit is faster?
If you have some sample code I could create some tests.
I guess the speed of comites will not change as Revit core is written in C/C++. Dotnet is used for UI (Ribbon, panels). The home page and project browser uses html+Js
I asked this question because it seems strange to me that changing multiple text parameters in multiple families or any similar SIMPLE operations takes literally a 5-10 seconds. I thought that when switching to Net.8, they optimized some of the "hard" points in transaction commit. Unfortunately, I don't have access to Revit 2025 yet, so I wanted to ask @ricaun if he noticed a significant increase in transaction commit speed in any of the fragments of his code available to him, between the previous version of Revit and Revit2025
Thanks for the answers!
this sound like interesting thing to try, when I will start moving to a 2025 I will try to make test for this for my last 4 versions I have.
Thanks for sharing the information and video.
Revit finally released and available for download?
@ricaun @nice3point @pieter4
Yes, yesterday Autodesk shared a YouTube video about the Revit 2025. https://youtu.be/7wD3aMUXquc?si=uXOcIqEgbMCMyrsK
