reload multiple links at once
acatonHL59J
acatonHL59J
It would be fantastic to be able to select multiple models or CAD files to reload at once rather than having to select each one at a time. I get that it would take longer - but at least i could set it to reloading and move on to another task while it works rather than having to babysit it and hit reload multiple times.
Yien_Chao
i think it's feasible with the API. Gather the links and their paths, then use the Reload() method :
https://www.revitapidocs.com/2022/86830eb9-5ddb-c342-fddd-6963e5c03564.htm
TripleM-Dev.net
Hi @acatonHL59J,
Uhm, you actually can. Just not a Mix of Rvt/Dwgs...or no longer possible in 2025?
Select all Rvt links in the manage dialog and hit Reload.
Multi ReloadMulti Reload
Or maybe you mean "Reload From"?
With the help of the API it's possible, I created a Re-path tool to change the path of linked Dwg's
- Michel
acatonHL59J
In 20-23 I cannot seem to select more than one link at a time. The reload button greys out when I do.
