REVIT 2024 running on parallels issue with Twinmotion
TVALLEJOZA
TVALLEJOZA
Have installed latest version of REVIT 2024 and Twinmotion on an Apple M2 with parallels. When using the inbuilt plug for Twinmotion to transfer the 3D model to TM it opens TM but the REVIT Modrl doesn’t appear. Appreciate help. Thanks
Yien_Chao
Ok this is not related to the API.
TVALLEJOZA
Thanks and excuse if I'm not well informed. Which would be the de appropriate forum for this question? thanks
moturi.magati.george
Hi @TVALLEJOZA,
Please note that this discussion forum is dedicated to programming Revit using the Revit API. Twinmotion are 3rd party developers hence you need to post this question on Twinmotion forum.
You can also try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us.
  Moturi George,     Developer Advocacy and Support,  ADN Open
