Cannot create point loads in Revit 2024
junlin001
Message 1 of 8
junlin001
1.  The example to create point load in Revit 2024 API (structure) does not compile
public void CreatePointLoad(Document document)
// Define the location at which the PointLoad is applied. XYZ point = new XYZ(0, 0, 4);
// Define the 3d force. XYZ force = new XYZ(0, 0, -1);
// Define the 3d moment. XYZ moment = new XYZ(0, 0, 0);
PointLoad pointLoad = PointLoad.Create(document, point, force, moment, null, null);
2. Then I tried to first create a host, then assign a load to the host
FamilyInstance instance = _document.Create.NewFamilyInstance(curve, symbol, levelBase, structuralType);
bool isValid = PointLoad.IsValidHostId(_document, elementId);
pointLoad = PointLoad.Create(_document,instance.Id, xyz, xyzForce, xyzMoment, null);
I got error "hostElemId is not permitted to host this type of load".
Can someone show me how I can create a point load the correct way?
Replies (7)
Message 2 of 8
moturi.magati.george
Hi @junlin001,
I have reproduced the issue and raised it with the development team here
I will update once they respond.
Thank you
  Moturi George,     Developer Advocacy and Support,  ADN Open
Message 3 of 8
Hello @junlin001,
I received a response from the development team.
Starting with Revit 2024 you can create only hosted loads. This is the reason why for this method you get an error: PointLoad pointLoad = PointLoad.Create(document, point, force, moment, null, null).
For the second case, where you pass host element id: accepted hosts are analytical members or analytical panels elements (this is the reason you get the error saying that "host is not permitted")
Message 4 of 8
junlin001
Thank you, Moturi.  Can you provide a simple example in c# or VB.NET here?
Message 5 of 8
RPTHOMAS108
The example you are looking for is already in the RevitAPI.chm under PointLoad.Create, when you use that you should pick an analytical element not a physical one (such as FamilyInstance).
Message 6 of 8
junlin001
This is the document I can find: https://help.autodesk.com/view/RVT/2024/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Discipline_Sp...
The code sample there does not work for me.
Where can I download RevitAPI.chm?  I cannot find the file under the installation folder (C:\Program Files\Autodesk).
Message 7 of 8
pierre
Thank you, however the only example I found in the PointLoad class in the RevitAPI.chm was: Getinfo_PointLoad(PointLoad pointLoad) which does not illustrate the Create method. Any chance you could post the sample you were referring to?
Message 8 of 8
junlin001
I was finally able to create a point load by
1. First create an AnalyticalMember and pass its elementId in the following
2. use PointLoad.Create(_document, elementId, xyz, xyzForce, xyzMoment, null);
