I have the latest version of Revit 2023 installed (2023.1.2) and also the latest version of IFC for R2023 (IFC23.3.0). My issue is when I click on the '...' in the parameter fields for "Export to IFC As" and "IFC Predefined Type", the dialog box/entity selector does not pop-up and so I am unable to populate these fields (typing does not work as well). I have tried alt-tabbing to see if the popup appeared elsewhere, also no. It also isn't hidden behind any windows.
Is there a way to fix this bug/issue? I have tried uninstalling and reinstalling the entire Revit software and it still does not work, even on Revit's sample project. Am at a complete loss and would appreciate any sort of help.
Hi @denise_chen
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
The people there are much better equipped to answer your question than us.
