Revit 2023: Getting normal/origin of FamilyInstance StrongReference ReferencePlane/Face
Jameshenager
Jameshenager
I'm trying to determine the origin and normal of a FamilyInstance which has a family with a plane with "Strong Reference". The purpose is to place another familyInstance in such a way that it lies along plane and another reference plane.
The loop runs as many times as there are strongReference planes.
My code is below:
    public void GetReferencePlanes(string selectedElementGuid)
        var doc = uiApplication.ActiveUIDocument.Document;
        if (doc.GetElement(selectedElementGuid) is not FamilyInstance familyInstance) { return; }
        var instanceGeometry = familyInstance.get_Geometry(new Options() { ComputeReferences = true, });
        var references = familyInstance.GetReferences(FamilyInstanceReferenceType.StrongReference);
        foreach (var reference in references)
            var f = doc.GetElement(reference).GetGeometryObjectFromReference(reference);
            if (doc.GetElement(reference.ElementId) is not { } referencedElement) { continue; }
            //get stable reference
            var stableReference = reference.ConvertToStableRepresentation(doc);
            var referencedElementType = referencedElement.GetType();
            var guid = referencedElement.UniqueId;
            var geometryObject = doc.GetElement(reference).GetGeometryObjectFromReference(reference);
            //var somePlanarGeometry = familyInstance.GetGeometryObjectFromReference(reference) as PlanarFace; //null
            var geometryType = geometryObject.GetType(); //always returns "Autodesk.Revit.DB.GeometryObject"
            switch (geometryObject) //none of these are ever hit
                case Curve curve: Debugger.Break(); break;
                case Edge edge: Debugger.Break(); break;
                case Face face: Debugger.Break(); break;
                case GeometryElement geometryElement: Debugger.Break(); break;
                case GeometryInstance geometryInstance: Debugger.Break(); break;
                case Mesh mesh: Debugger.Break(); break;
                case Point point: Debugger.Break(); break;
                case PolyLine polyLine: Debugger.Break(); break;
                case Profile profile: Debugger.Break(); break;
                case Solid solid: Debugger.Break(); break;
                default: break;
            Debugger.Break();
Jameshenager
Solution here:
    private static List<NamedPlane> GetReferencesPlanesByTypeCore(Document doc, string familyInstanceGuid)
        if (doc.GetElement(familyInstanceGuid) is not FamilyInstance familyInstance) { return []; }
        var result = new List<NamedPlane>();
        var familyInstanceReferenceTypes = Enum.GetValues(typeof(FamilyInstanceReferenceType)).Cast<FamilyInstanceReferenceType>().ToArray();
        foreach (var familyInstanceReferenceType in familyInstanceReferenceTypes)
            List<Reference> references = familyInstance.GetReferences(familyInstanceReferenceType).ToList();
                var sketchPlane = SketchPlane.Create(doc, reference);
                var plane = sketchPlane.GetPlane();
                result.Add(new NamedPlane() { Name = familyInstance.GetReferenceName(reference), Origin = plane.Origin.ToPoint(), Normal = plane.Normal.ToPoint(), });
                sketchPlane.Dispose();
        return result;
public class NamedPlane
    public string Name { get; set; } = null!;
    public Point Origin { get; set; } = null!;
    public Point Normal { get; set; } = null!;
public class Point
    public double X { get; set; }
    public double Y { get; set; }
    public double Z { get; set; }
