Revit 2022 SetActivePredefinedPDFSettings?
PaulCollins7972
PaulCollins7972
Is there a way to change the document ExportPDFSettings from the API in Revit 2022?
I can see ExportPDFSettings.GetActivePredefinedSettings but not how to set the setting seen in the UI. I have an addin that lists all the settings found in the current document and was hoping that the user could pick one from a list and make that current. I have Revit 2022.1.
PaulCollins7972
As many people have looked but nobody has replied I take it that setting the active PDF export setting from the API is not possible at the moment. For my purposes I have found another way to achieve what I want.
Maybe the functions available from the UI (Save, Rename, Delete etc.) can be added to the API at some future release?
