NewAlignment:the two references are not geometrically aligned
SimonaQQ
SimonaQQ
hello,
How can i achieve the condition of geometrically aligned?
I use the following code to test the newalignment API, but always throw an exception of "the two references are not geometrically aligned". What is the reason? What is "geometrically aligned" mean?
thank you
var uidoc = commandData.Application.ActiveUIDocument;
                var doc = uidoc.Document;
                var selection = uidoc.Selection;
                using (Transaction tra = new Transaction(doc, "33"))
                    tra.Start();
                    Line line0 = Line.CreateBound(XYZ.Zero, new XYZ(10, 0, 0));
                    Line line1 = Line.CreateBound(new XYZ(0, 10, 0), new XYZ(10, 10, 0));
                    var l = doc.Create.NewDetailCurve(doc.ActiveView, line0);
                    var ll = doc.Create.NewDetailCurve(doc.ActiveView, line1);
                    doc.Regenerate();
                    doc.Create.NewAlignment(doc.ActiveView, new Reference(l), new Reference(ll));
                    tra.Commit();
                return Result.Succeeded;
RPTHOMAS108
RevitAPI.chm for ItemFactoryBase.NewAlignment
"These references must be already geometrically aligned (this function will not force them to become aligned)."
Your lines need to be parallel and geometrically aligned to start with (overlapping) and then NewAlignment will add a lock alignment between them.
SimonaQQ
So which rule does the two lines in the code violate?
