Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit 2021 Dimesions not performing as expected
2 REPLIES 2
ElrinaMills
432 Views, 2 Replies
Has anyone noticed in Revit 2021, when trying to add a pre-or suffix to a dimension, that the dialog shows the actual value as 0? The properties of the dimension still display correct, but not in the dialog.
@joan_allen   is this something that the development team is aware of? can we expect a fix in an upcoming update?
If this answer provides a solution, please mark this post as the solution.
Elrina Mills
Labels (1)
2 REPLIES 2
Hi @ElrinaMills ,
Yes, the development team is aware of this issue and they are working on it.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Great, thank you
Elrina Mills
Rail Community
