Prevent Modeless Multiple Instance
LandformX
LandformX
Hi All,
I'm submitting application to Autodesk app store and one of their comment about my application is it's opening multiple instances every time you click its button. I've search on forums and found out same question here , Jeremy's answer was to change it from "Show" to Showdialog, however i'd like to keep my application as modeless form as much as possible. Is there anyway to do this or do i really need to make it modal form? Thanks in advance.
RPTHOMAS108
Yes you track if the window is open or not.
If you put the window on a static variable then upon window closed event you set this variable to nothing. When you activate your command you always first check if static variable is not nothing (window already open). If static variable is nothing the window can't already be open so you assign a new instance of the window to the variable and show it.
LandformX
Thanks @RPTHOMAS108  would you mind giving an example? Please, Thank you.
RPTHOMAS108
Slightly different from suggested using Boolean to check if window is open or not:
public class xx : IExternalCommand
	private static LocatePointWindow CoordWind = new LocatePointWindow();
		//Public so can be set to false from Window closed event
	public static bool WindowActive = false;
	public Autodesk.Revit.UI.Result Execute(Autodesk.Revit.UI.ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
		if (WindowActive == false) {
			CoordWind.Show();
			WindowActive = true;
		return Autodesk.Revit.UI.Result.Succeeded;
LandformX
Thank you @RPTHOMAS108  🙂
