Revit 2020 Install (Stuck)_
!Dalton_Goodwin!
!Dalton_Goodwin!
The install of Revit 2020 is stuck at Autodesk Revit 2020 | 485 MB of 7.52 GB download.
I have read the Autodesk_Revit 2020_Readme and I have the right system configs.
Any ideas? Is this happening to anybody else?
Thanks for any help.
jeremytammik
Dear Dalton,
Thank you for your query.
I installed OK, and had no problems:
https://thebuildingcoder.typepad.com/blog/2019/04/the-revit-2020-fcs-api-and-sdk.html
However, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, unfortunately, this is not the best place to ask such a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
!Dalton_Goodwin!
My apologies, I wasn't entirely sure where to post this, being that it isn't a discipline specific question. I did not know about the Installation & Licensing forum so thank you for the info.
