preset choices in the dialog brought up by PostRequestForElementTypePlacement
thomier
thomier
I am using the following code to bring up the placement dialog for conduit:
var typeToPlace = new FilteredElementCollector(_document)
.OfClass(typeof(ConduitType))
.Cast<ConduitType>()
.Where(x => x.Name == "Rigid Nonmetallic Conduit (RNC Sch 40)")
.FirstOrDefault();
_uiDocument.PostRequestForElementTypePlacement(typeToPlace);
it works but I want to preset the diameter based on the user's choices in a previous dialog and I cannot figure out how to do this through the API.
The screenshot's attached highlight exactly what I am trying to pre-populate
jeremytammik
I believe you can achieve what you wish using SetDefaultFamilyTypeId:
https://apidocs.co/apps/revit/2019/1f0d5aac-4602-b479-82b4-dc54a030c0a3.htm
Some further discussion with more details on this happened here:
https://forums.autodesk.com/t5/revit-api-forum/change-the-placement-option-for-promptforfamilyinstan...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
thomier
public void SetDefaultFamilyTypeId(
	ElementId familyCategoryId,
	ElementId familyTypeId
doesn't seem to help me b/c both conduit runs with a 2" and a 4" diameter have the same exact familyTypeId.
And looking at the other link I wasn't able to see how that would help me either.
If I have to I can just leave it up to the user but I would much rather set the values as I already know what they need to be.
Tony
jeremytammik
One simple and effective thing you could do would be to post-check the conduits after the user has finished placing them and display a warning if the dimension they selected does not meet your expectations...
Jeremy Tammik
The Building Coder
mastjaso
Wouldn't that mean that the diameter is not a type property but is instead an instance property?
thomier
It is an instance property that the dialog presets as the conduit is placed, I was just hoping there was a way i could control the values the dialog presents to the userValue I wish to prepopulate.PNG
mastjaso
Oh yeah, I see what you mean, I think that's similar to this thread about pipes:
https://forums.autodesk.com/t5/revit-api-forum/change-the-system-type-for-pipe-creation-via-ui/td-p/...
But the general long and short of it is that I don't think you can entirely do what you want to do easily ...
