AngleAboutAxis in C#
vanlion
vanlion
I'm trying to get the same result from the dynamo node vector.AngleAboutAxis in dynamo with the following code in C#. But the result isn't the same as you can see under the dynamo node and my C# results. Does anybode know how to do this in C#?
// new XYZ from average point
XYZ pA = new XYZ(averageX, averageY, 0);
XYZ pB = new XYZ(averageX-100, averageY, 0);
 XYZ res = pA - pB;
//Other vector from all points foreach (XYZ d1 in coord) { XYZ vv = res -d1; double angle = vv.AngleTo(res); double resultAngle = angle * 180 / (Math.PI); }
jeremytammik
Please explain exactly what you are trying to achieve.
Does anybody know how to do this in C#?
'This' is not clear to me.
Jeremy Tammik
Developer Technical Services
The Building Coder
vanlion
Hi Jeremy,
I already found how to do this in C#. In the picture below you can see how to translate the Vector.AngleAboutAxis in dynamo. With this diagram (in yellow) it is very easy to make the convertion to C#.
dhanait_ajay13
can you please share the code with me? how we can convert
jeremy_tammik
For me, it would be easier if you describe exactly what you are trying to achieve in pure geometric terms, since I am not familiar with the Dynamo node that you refer to. It is probably really simple and a standard operation, but which one?
