Revit 2020 Addin Manager missing?
davidd
Message 1 of 9
davidd
Hi All,
I've downloaded the Revit 2020 SDK from the Revit development centre (https://www.autodesk.com/developer-network/platform-technologies/revit).
The package is missing the Addin Manager. Does anyone know where i find it for Revit 2020?
Dave
Replies (8)
Message 2 of 9
a180401ta
I am also using the old version.
But can be used on revit 2020.
You can try.
The installation path is the same.
Please notify if successful.
C:\ProgramData\Autodesk\Revit\Addins\2020
Message 3 of 9
davidd
Thanks for the relpy and point in the right direction a180401ta.
I copied the .dll and .addin from the 2019.2 SDK into C:\ProgramData\Autodesk\Revit\Addins\2020 and all works as it should.
Cheers!
Dave
Message 4 of 9
jeremytammik
Dear Dave,
Thank you for your query, and many thaks to Abel for the simple solution!
Several others have already asked the same question, so I pubblished this solution on The Building Coder:
https://thebuildingcoder.typepad.com/blog/2019/05/spatial-geometry-add-in-manager-and-show-reels.htm...
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 5 of 9
j_weber
Thanks a lot.
copy in my folder and see it in my Revit 2020
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
Message 6 of 9
arshad.k
I followed the same instructions, but plugin doesn't opening!!!. Im using Revit 2020
Any updated versions anybody has, Kindly share it..
Thanks and Regards
Arshad.K
Message 7 of 9
Brilliantowww
Google translated by Community manager:
If the launch does not occur at all (there is no reaction to a click on the plugin icon)
THEN most likely the version of the plugin is not correct, for 2021 you need a plugin 2021 from the revit SDC 2021 collection
If the plugin is launched with error warning dialog boxes
Just open the file "Autodesk.AddInManager" in an IDE such as Visual Studio and fix the errors that are indicated in the dialog box ...
See screenshots below
Если запуск не происходит вообще (нет реакции на клик по иконки плагина)
ТО скорее всего версия плагина не верна, для 2021 нужен плагин 2021 из сборника revit SDC 2021
Если же плагин запускается с диалоговыми окнами предупреждающими об ошибках
Просто откройте файл "Autodesk.AddInManager" в IDE например Визуал Студии и поправите ошибки которые указаны в диалоговом окне...
Смотрите скрины ниже
Message 8 of 9
jeremy_tammik
Many thanks to Brilliantowww for the explanation.
Google translates as follows:
If the launch does not occur at all (there is no reaction to a click on the plugin icon),
THEN most likely the version of the plugin is not correct. For 2021, you need a plugin 2021 from the Revit 2021 SDK.
If the plugin is launched with error warning dialog boxes,
Just open the file "Autodesk.AddInManager" in an IDE such as Visual Studio and fix the errors that are indicated in the dialog box.
See screenshots below.
Message 9 of 9
DanielKP2Z9V
