How can I generate such a virtual line segment effect?
AD8080202
AD8080202
在“測量”命令下,您可以看到虛擬線段。
但我沒有找到提供這種做法的代碼?
這不是一種有效的工作方式。
有什麼建議?我們如何解決這個問題?
非常感謝任何幫助。
AD8080202
Sorry, I don't know why the text will be converted.
Re-inquire.
Under the "Measure" command, you can see the virtual line segment.
But I did not find the code to provide this practice?
This is not an efficient way of working.
Any suggestions? How do we fix this?
Any assistance is much appreciated.
AD8080202
I had checked but was told it didn't provide this function. It is true? Any response is greatly appreciated.
jeremytammik
Yes, it is true. The Revit API does not support rubber-banding on user input, i.e., these virtual lines.
Jeremy Tammik
Developer Technical Services
The Building Coder
