Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit 2019 crashes after selecting a plate in a steel connection
2 REPLIES 2
Nurlan-A.
679 Views, 2 Replies
Hello!
I made a macro for entering data into the parameters of the plates. After starting and completing the macro, if I select any plate in any steel connection, Revit crashes.
What can be wrong?
I found this in the Revit journal:
' 0:< DBG_WARN: Current ParameterValue is not applicable to ElementIdParameterValue
'Expect a soft crash after this warning.
'ApplicationException is being thrown on behalf of the function <class ElementId __cdecl ParameterValue::asElementId(void) const>.
and this
' 0:< DBG_INFO: Recent Dynamic Added but not to Dynamics, this means that this element is not dynamic anymore with RDYs removed.: line 185 of
2 REPLIES 2
Nurlan-A.
in reply to: Nurlan-A.
Since it is temporarily impossible to attach files, link to a problematic sample: https://1drv.ms/u/s!Ap6SgQpJO4sPhNQusuXO2Ye80y7UYw
If you open this model and try to select a plate in the steel connection, Revit will crash.
Extraneous
I cought the same issue with Plate's parameters. It happened when I wrote String value into "Material" parameter. It is strange, because I don't have the same problems with other elements, like beams or columns: string value is succesfully written in Material parameter. But Revit crashes if you make it with SteelPlates. And journal says it for us: incorrect parameter value.
Alexander Zuev
In BIM we trust
Facebook | Linkedin | Telegram
Autodesk Customer Advisory Groups
Rail Community
