Revit 2020 API: ViewName Property Missing
On the Revit Documentation is noted that on Revit 2020 the ViewName Property is no longer available as it was for the preview versions of Revit. I cannot find an explanation for that. Any idea how to solve that?
http://www.revitapidocs.com/2020/d13cf4c1-1f5f-e7af-8aed-91197ee24b92.htm
ahmadizm
I think you can just use the Name property (inherited from Element).
jeremytammik
Dear Luis,
Thank you for your query, and many thanks to @ahmadizm for his helpful suggestion, with which I fully agree.
Unfortunately, the removal of this property was not mentioned in What's New in the Revit 2020 API:
https://thebuildingcoder.typepad.com/blog/2019/04/whats-new-in-the-revit-2020-api.html
Sorry about that.
What a handy link and nice multi-version comparison functionality provided by RevitApiDocs! Goes to show that automatically generated documentation sometimes has significant advantages.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Archigrafix_Norge
[ObsoleteAttribute("This property is deprecated in Revit 2019 and will be removed in the next version of Revit. We suggest you use 'Element.Name' property instead")]
Luis Santos
archi systems as
techXMKH9
Just in case anybody is stuck  with Autodesk.Revit.Exceptions.ArgumentException:
// Thrown when the element requires a unique name and a non-unique name is set.
View name should not contain curly bracket i.e "{}".
joshua.lumley
Here is the solution: search for all instance of ".ViewName" and replace with ".Name".
Problem solved.
