Revit 2017 Export to IFC
Hi all,
I have an issue while trying to export an IFC model from Revit 2017. The export starts and freezes at some point and fail. I have tried the following:
  • Reinstall and update the IFC export addins (and made sure only one version is installed)
  • Audit and detach the model before export
  • Hide worksets in view and export visible in view option (to eliminate the size issue)
  • Upgrade the model to Revit 2019 and export
  • Tried different export options including (very low level of details option)
  • Tried to export on different machines
  • Turned off the hard graphic acceleration
All failed. I have been checking the journal document after each attempt and it shows the same error:
“1:< DBG_INFO: Inconsistency in solid faceting: we reached the end of the list of vertices on one face, but not the other.: line 3275 of SolidUtils.cpp.”
And this is where it freezes. The issue is that the export freezes at different elements during each attempt. I really need to have the IFC exported, it is required by the client.
help please!
jeremytammik
Dear Hamzeh,
The best place for you to get rapid and knowledgeable answers to issues concerning the Revit IFC importer and exporter is the discussion group on the open source IFC for Revit project:
https://sourceforge.net/p/ifcexporter/discussion/general
Furthermore, if you are not doing anything programmatically yourself, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Noted. Thanks you!
