public class Class1 : IExternalApplication
// Implement the OnStartup method to register events when Revit starts.
public Result OnStartup(UIControlledApplication application)
// Register related events
application.DialogBoxShowing +=
new EventHandler<Autodesk.Revit.UI.Events.DialogBoxShowingEventArgs>(AppDialogShowing);
return Result.Succeeded;
// Implement this method to unregister the subscribed events when Revit exits.
public Result OnShutdown(UIControlledApplication application)
// unregister events
application.DialogBoxShowing -=
// The DialogBoxShowing event handler, which allow you to
// do some work before the dialog shows
void AppDialogShowing(object sender, DialogBoxShowingEventArgs args)
// Get the string id of the showing dialog
String dialogId = args.DialogId;
// Format the prompt information string
String promptInfo = "A Revit dialog will be opened.\n";
promptInfo += "The DialogId of this dialog is " + dialogId + "\n";
promptInfo += "If you don't want the dialog to open, please press cancel button";
// Show the prompt message, and allow the user to close the dialog directly.
TaskDialog taskDialog = new TaskDialog("Revit");
taskDialog.Id = "Customer DialogId";
taskDialog.MainContent = promptInfo;
TaskDialogCommonButtons buttons = TaskDialogCommonButtons.Ok |
TaskDialogCommonButtons.Cancel;
taskDialog.CommonButtons = buttons;
TaskDialogResult result = taskDialog.Show();
if (TaskDialogResult.Cancel == result)
// Do not show the Revit dialog
args.OverrideResult(1);
else
// Continue to show the Revit dialog
args.OverrideResult(0);
Here is the minimal reproducible case.
