Export menu not giving "report" option
eneumann
eneumann
After generating a schedule in Revit, I tried to export it.  When i went to R>Export, the report option is not there.  Can someone please explain?
jeremytammik
Dear Eric,
Thank you for your query.
Unfortunately, I do not know the answer off-hand.
Are you doing anything programmatically, or just using the standard Revit user interface?
If you are not doing anything programmatically, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
