Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit 18 stopped working after Nvidia driver update
3 REPLIES 3
317 Views, 3 Replies
Hi All,
Hopefully, someone can help.
I have Revit 2018 on Windows 8.1 with Nvidia GeForce 840m as graphic card.
To install Enscape, I had to update my graphic card with the latest driver compatible: Game Ready Driver 456.71
Once installed, Revit crahes as soon a file is open with the following error message: "Video Driver error has occurred".
To use Revit now, I need to disable the graphic card from the control panel.
Any idea about how to sort out the issue?
All help is appreciated.
Many thanks
Davide
Hi All,
Many thanks
Davide
3 REPLIES 3
jeremytammik
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, if you are not programming anything yourself using the Revit API, this is not the right place for this question.
Therefore, you cannot expect an answer to a question such as yours relating to licensing, installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
in reply to: jeremytammik
Thanks for the tip Jeremy.
I am moving the post in another section or the forum.
Kind regards
Davide
Kind regards
Davide
I am moving the post in another section of the forum.
Kind regards
Davide
Kind regards
Davide
