retrieve properties of element
I want to retrieve property of structural framing. How I retrieve it? I want its cut length, volume,area and length using c# code
Aaron.Lu
Element.GetOrderedParameters()
or Element.get_Parameter(string)
or Element.get_Parameter(BuiltInParameter)
Tips:
use RevitLookup tool to spy the objects inside Revit, you will get the idea.
download RevitSDK to learn from Revit addon sample code.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
If I want to resize the cut length of the structural framing,How I do this? My target is to make structural framing cut length and Length is equal.
Aaron.Lu
