Resize cut length of family instance
I want to resize the cut length of the family Instance. Firstly I get cut length and length of the family instance and I want to make the cut length equal to  length of the family Instance.
Firstly I get cut length and length of the family instance then I want to substract cut length from length and I get new value.If I add that value in the cut length I will get new cut length which is equal to length of the family instance.This is my target.How I achieve this?
what changes should I make in this code?
Here is the code which I am using:
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace JoinGeometry
     [Transaction(TransactionMode.Manual)]
    class WBjoin
           public Result Execute(ExternalCommandData commandData)
                  UIApplication uiApp = commandData.Application;
                  UIDocument uidoc = uiApp.ActiveUIDocument;
                  Document doc = uidoc.Document;
                 try
                              FilteredElementCollector wallbeam = new FilteredElementCollector(doc, doc.ActiveView.Id);
                              wallbeam.OfClass(typeof(FamilyInstance));
                              wallbeam.OfCategory(BuiltInCategory.OST_StructuralFraming);
                              foreach (FamilyInstance bem in wallbeam)
                                              using (Transaction t = new Transaction(doc, "Join All Walls/beam"))
                                                            t.Start();
                                                           BuiltInParameter paraIndex = BuiltInParameter.STRUCTURAL_FRAME_CUT_LENGTH;
                                                           Parameter parameter =bem.get_Parameter(paraIndex);
                                                            double hypotenuse = parameter.AsDouble();
                                                              TaskDialog.Show("Revit", "cut length=" + hypotenuse);
                                                              t.Commit();
                    catch
                                  TaskDialog.Show("Revit", "not join");
                return Result.Succeeded;
Aaron.Lu
call parameter.Set(1.0) to set cut length to 1.0 feet
Aaron Lu
Developer Technical Services
Autodesk Developer Network
