Retrieve list of possible values for a parameter
mikkelnymand4EMUM
mikkelnymand4EMUM
I want to retrieve a list of possible values for a given parameter.
Fx. if we look at the Phase Created parameter of a given element, the parameter can only be the phases contained within the open project - how do I retrieve this list?
I found this old stackoverfllow question where it doesn't seem possible, but has anything changed in that regard?
Jeremy Tammik says NO
For context:
I'm making a GUI where you can filter doors, and I want to be able to filter based on any parameter of the doors - the list of parameters I get with GetOrderedParameters() on a given door.
When the user chooses a parameter like width I show a textbox, but if they select something like Phase Created I want to show a combobox containing the values you can choose.
Any ideas or workaround is also greatly appreciated I feel like I've emptied out my own ideas besides hardcoding based on the phases of the project for the Phase Created parameter, but I would like a more elegant solution.
jeremy_tammik
If you want to filter for doors and present a list of all existing parameter values for each parameter on each door, that can very easily be achieved by retrieving all doors and all their parameters and simply creating a list of all unique values encountered.
A related and more complex task is implemented by the AdnRevitApiLabsXtra samples:
  • Labs4.cs – Lab4_2_ExportParametersToExcel: Export all parameters for each model element to Excel, one sheet per category
mikkelnymand4EMUM
Hey Jeremy
Thank you for the reply.
I've already successfully retrieved a list of the parameters from a door in the project, and I'm then using those values as a combobox.
What I wanted to do, was display a new combobox if "Phase Created" was selected and have that combobox populated with all the current phases in the project, and if the "Mark" or "Comment" parameter was selected I wanted to display a textbox etc.
For now I've settled with always showing a textbox, and the user have to type the relevant phase. It works fine 🙂
