Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Retrieve CUT_EDGE References from walls
7 REPLIES 7
Message 1 of 8
josepht21
695 Views, 7 Replies
Hi everybody!
I am trying to get the CUT_EDGE references of a given wall using the API. At the moment I can get part of the references based on the Wall geometry. I first go to the Solids and for each edge of the solid I check if the Reference is of type CUT_EDGE. This works but does not get all the options (I see more when generating a dimension line manually in the UI of Revit).
For example I have the wall seen in the image with the dimension that is attached to the CUT_EDGE references:
3aecdde0-f1aa-42b2-a208-f740e7a17720-003f7f7f:8:CUT_EDGE/0/1 and 3aecdde0-f1aa-42b2-a208-f740e7a17720-003f7f7f:8:CUT_EDGE/1/1. But when I run over all the edges of the wall I only get the following options (see image attached).
I played already with the visibility and detail options and nothing helps.
@jeremy_tammik
Labels (5)
7 REPLIES 7
Message 2 of 8
jeremy_tammik
in reply to: josepht21
Did you test using the IncludeNonVisibleObjects property?
https://www.revitapidocs.com/2024/0d277b80-d5e5-1151-d413-b0899da0976f.htm
Message 3 of 8
josepht21
in reply to: jeremy_tammik
Yes, I did use that property. I think knowing better what the structure of this stable representation means could help a lot 3aecdde0-f1aa-42b2-a208-f740e7a17720-003f7f7f:8:CUT_EDGE/0/1.
Message 4 of 8
jeremy_tammik
I can imagine that a CUT_EDGE reference is generated dynamically by a cut, so you cannot retrieve it from any existing BIM element geometry. It is the result of a cut between more than one element, and no single element or element geometry can provide that.
Message 5 of 8
josepht21
So here is my finding that actually worked, for example using the Stable Representation 3aecdde0-f1aa-42b2-a208-f740e7a17720-003f7f7f:8:CUT_EDGE/0/1.
3aecdde0-f1aa-42b2-a208-f740e7a17720-003f7f7f: Refers to the element itself
8: Is the ID of the face of the Revit Element.
CUT_EDGE/0/1: This is the type and location of the Reference. It is CUT_EDGE type and the 1 means which edge of the face and the 0 the end-point of it.
My original findings were correct I was just missing the index of the end-point of the edge I found. All this is possible to find via the Edges of the Solids that are part of the geometry of an Element.
Message 6 of 8
jeremy_tammik
Message 7 of 8
jeremy_tammik
Edited our conversation and added to the blog:
https://thebuildingcoder.typepad.com/blog/2023/10/no-geometry-touching-geometry-and-cut-geometry.htm...
Message 8 of 8
josepht21
Amazing! Thanks
