Intersections with FamilyInstance with extrusion
Leonardo252627
Message 1 of 1
Leonardo252627
Community Visitor
Community Visitor
Hi!
I have a model with intersecion like on attached image "Intersecion.png".
The problem is with appling ElementIntersectsElementFilter to FilteredElementCollector when I tring to find intersection between some element (Pipe for example) and any FamilyInstance with extrusion.
It can't find intersection like on the attached images.
Tee familyInstance (see Familysymbol.png) contains 2 extrusions and 3 couplings.
It works fine when I try to find intersections between pipe and tee's couplings, but falied with extrusions.
It finds correct intersections between all tee's components when i use BooleanOperationsUtils (see code below).
But this approach doesn't suits to me, because it demands to get single element's solid. This is an issue because i have sometimes elements with > 100 subsolids and the same boolean Union operation takes a long time and often have a lot of fails.
I tried to detect elements of  this type but couldn't find any ways to detect extrusion inside FamilySymbol of this FamilyInstance.
I would be appreciated if anyone could help me.
var collector = new FilteredElementCollector(doc, elementIds);
var filter = new ElementIntersectsElementFilter(pipe);
var intersectionElements = collector.WherePasses(filter).ToElements().ToList(); //intersectionElements.Count==0
var pipeSolid = pipe.Solid();
var teeSolid = tee.Solid();
var interesectionSolid = BooleanOperationsUtils.
ExecuteBooleanOperation(pipeSolid, teeSolid, BooleanOperationsType.Intersect); //intersectionSolid.Voume = 0.0083216139902945029
Replies (0)
