Retrieve Area Boundary
Moshe-A
Mentor Mentor
Moshe-A
Hi Guys,
i want to retrieve the Lines contour of an Area Boundary Element and i'm stuck
actually i do not know how to iterate the result coming from Area.GetBoundarySegments()
thanks in advance
Moshe
namespace MyNameSpace
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.ReadOnly)]
    public class Class1 : IExternalCommand
        public Autodesk.Revit.UI.Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            try
                Document document = commandData.Application.ActiveUIDocument.Document;
                AreaFilter filter = new AreaFilter();
                FilteredElementCollector collector = new FilteredElementCollector(document, document.ActiveView.Id);
                IList<Element> elementAreas = collector.WherePasses(filter).WhereElementIsNotElementType().ToElements();
                IList<IList<BoundarySegment>> boundarySegments;
                foreach (Element elem in elementAreas)
                    Area ba = elem as Area;
                    boundarySegments = ba.GetBoundarySegments(new SpatialElementBoundaryOptions());
                    // stuck here ???
            catch (Exception e)
                message = "Unexpected Exception thrown.";
                return Autodesk.Revit.UI.Result.Failed;
           return Autodesk.Revit.UI.Result.Succeeded;
jeremytammik
Dear Moshe-A,
Try this:
http://lmgtfy.com/?q=revit+api+GetBoundarySegments
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Moshe-A
thank you
jeremytammik
my pleasure entirely  🙂
Jeremy Tammik
The Building Coder
