gbXML Export Complexity
I am a programmer with the Center for Research Computing at Notre Dame. I need to programmatically export a drawing in RevIt to gbXML. I am able to do this successfully, however, the "Export Complexity" is set to "Simple", which discards some data that is vital our analysis process. When exporting manually, we set this property to "Complex with Mullions and Shading Surfaces" in the export dialog. Is there a way to set this property of the export process when exporting through the API? Everything I've read seems to indicate that it is not possible. For reference, we are using RevIt 2014.
Thanks in advance,
Scott Szakonyi
Research Programmer
University of Notre Dame
jeremytammik
Dear Scott,
I asked the development team and learned from your namesake Scott Conover that you should be setting EnergyDataSettings.ExportComplexity.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
This worked perfectly, thank you!
