Renumbering Detail Number based on location
BCampbellNWL
BCampbellNWL
Hey all! I'm developing a tool that will renumber views on a sheet based on their location in relationship to our title block. I'm super close, but when I go to set the value nothing happens. Anyone know why the SetValueString() method wouldn't work?
FilteredElementCollector viewportCollector = new FilteredElementCollector(doc.ActiveView.Document)
                .OfCategory(BuiltInCategory.OST_Viewports)
                .WhereElementIsNotElementType();
int arbitrarySet = 1000;
Transaction t2 = new Transaction(doc);
    t2.Start("Reset Detail Numbers");
    foreach (Element vp in viewportCollector)
              arbitrarySet++;
              vp.get_Parameter(BuiltInParameter.VIEWPORT_DETAIL_NUMBER).SetValueString(arbitrarySet.ToString());
      t2.Commit();
(This portion is designed to renumber them to something arbitrary to avoid duplicate errors)
  • API
RPTHOMAS108
Note remarks section for Parameter.SetValueString in RevitAPI.chm:
"The method only applies to parameters of value types."
String is not a value type so use Parameter.Set.
There is also unit parsing overhead associated with SetValueString for value types.
BCampbellNWL
@RPTHOMAS108  Thank you so much! Worked Like a charm! This API can be very confusing sometimes! haha I'll get the hang of it eventually!
