Remove/hide native buttons using the REVIT API
Hi all,
Could you let me know if there is any way to remove/hide native buttons from Revit 2022 using the API provided?
I wish that in the "collaborate" tab I could hide the "Synchronize with central" button.
The intention is to extend the logic of this button by creating a new one.
I'm using .NET as a language to interact with the API...
Thanks.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Please try using this below sample code
 Autodesk.Windows.RibbonControl ribbon = Autodesk.Windows.ComponentManager.Ribbon;
                foreach (Autodesk.Windows.RibbonTab tab in ribbon.Tabs)
                    if (tab.Title.Contains("Collaborate"))
                        foreach (Autodesk.Windows.RibbonPanel panel in tab.Panels)
                          if(panel.Source.Id== "central_file_shr")
                              RibbonItemCollection collctn=panel.Source.Items;
                              foreach(Autodesk.Windows.RibbonItem ri in collctn)
                                 if(ri.AutomationName== "Synchronize with Central")
                                        ri.IsVisible = false;
                                        ri.ShowText = false;
                                        ri.ShowImage = false;
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Hi Naveen!
Your example worked correctly.
Thank you very much.
Best Regards,
Yuri Bezerra.
RPTHOMAS108
You can probably override the built in command via command bindings, at least then the button would still be where people expect it.
Buttons not where they are expected to be, just very annoying. Makes you want to just unload all the add-ins to find the culprit.
Like in the old days when your browser home page got changed by a website, what was that called again (something hijack)?
jsnowHJVYV
what did you use to access the api for that
i tried "usingn Autodesk.UI.Windows;" and got nothing.
it wont recognize the code u have posted
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @jsnowHJVYV ,
1)Add reference "AdWindows.dll" from "C:\Program Files\Autodesk\Revit 202x"
2)Add namespace "using Autodesk.Windows;" to the code
3)Now you should be able to access the RibbonControl.
I hope this helps.
Naveen Kumar T
